My mechanic friend came out and took the old wiring and control box for the snow wing off. The wires at each end were in terrible shape. Surprised nothing shorted out. There were a couple extra power wires so he used one to power the switch and then used a couple wires coming out of the cab that were used for the snow wing. Just had to add about a 2' foot section of 2 wire cable to reach the solenoids. Zip tied the cable to 1 of the hydraulic hoses to keep it from flopping around and coming apart. Works good and isn't overly fast where it slams the ripper hard up to the stops. The 2 cylinders have a lot of power. Tried it out with just 1 tooth and I think it will work good for ripping the hard packed clay on my MX track so the water will drain better. Two pins for the ripper teeth are the wrong size so I'll make some new ones.
