JfitzCat
I had been following your thread. lots of good info in it that’s applicable to my machine. I agree man, the accessibility of the seal area is just awful. I cleaned both sides of mine out the other day. You can’t even reach your hand in there behind the sprocket, there is no room at all. I had to just start chiseling from between each tooth on the sprocket until the clump was broken up enough to fall down and then had to chisel that up until it could be pulled out of the area entirely, if that makes any sense. But it’s fairly clean now. it’s just something else I’ll have to add to my maintenance regimen.Thanks all for ongoing discussion on this, albeit to some extent redundant. I'm wrestling with similar issues described some here: https://www.heavyequipmentforums.com/threads/304cr-final-drive-alarmist-oil-sampling.106987/
...especially the cleaning out of mud and crud from the seal area Nige graciously posted in the above thread,; I can say I was on my back just yesterday with a sort of custom scraper tool I made, digging crap out of the cavities on the 304 with nearly 5000hrs, without removing the track. It may not be any less futile than a lot of other sorts of remote property management I'm involved with year round! At this point, I'm not a big fan of the design, to make a critical seal area so prone to mud cakes so inaccessible, but I'm not a mechanical engineer. I'm just a schlub who's seen too many pictures of WWI tanks, thinking they managed to work in the trenches, at least for a minute or two.
I've done a bunch of flushing and oil changes also, and taken y'all's advise to run TO-4 50 - holding my breath on another set of SOS in 100 hours or so. I do a significant amount of travel and dozer work with the thing. Anyway, I have a tendency to over-think things and it is helpful when all the experience here says relax, change the oil often, it's cheap, and pay attention to how the machine responds.
Please report back with your ongoing experience on the matter.
-gibbs
I do a lot of tracking as well. It’s not the kind of machine that spends most of its time stationary. At the least it’s always moving back and forth in our wood yard moving logs around, and sometimes goes out on longer travel bouts like when I’m cleaning up our trail system.
Overthinking is what I do best. Both of our threads are great examples of people that overthink stuff lol. I’m definitely interested in how your next analysis looks with 50wt TO-4 after all the flushing. I’m going to pull my next one at the 50hr mark. That’s sufficient of time for an accurate sample in my experience. When I took my machine in for Cat to inspect the drives the oil had just 16hrs on it and they pulled a sample of it when they drained it. And the results were already not good. Iron and oxidation were highly elevated already. So I figure 50hrs will be more than enough to see if this new oil is doing any better than the GO was. Seems like we do somewhat similar work with our machines so the samples should give us pretty good insight into 30wt vs 50wt TO-4.
