Jeembawb
Hey Jeembawb, I've probably missed something in one of your earlier posts, but why did you deem it necessary to lift the front of the tractor to work on the rear end?
Cheers, Greg
The rear will get jacked up slightly soon too - but no need until the trans/final drive cover comes off because it makes it unnecessarily higher to work on & to lift stuff off with the forklift. When the trans/ f/d cover comes off the tracks need to be off the ground to be able to rotate the final drive to undo the bolts for it. Gunna do a little work on some of the grousers too while its up.
Jimbob
