451C in the Adelaide Hills
Hi All,
I've been following this thread for a year or so now, and it seems now is the time to make my first post. A 451c came into my care almost 2 years ago. It had been sitting out in the weather, under a tarp for about 5 to 10 years. I'll give a quick history of where I'm at with it:
Dropped the engine oil. This was ok.
Dropped the transmission and final drives oil. The final drives and transmission had taken in a large amount of water and came out of the drain hole looking like a light brown custard. I took the covers off the bottom of the final drives and cleaned these as much as possible, but I let the trans/diff drain for a couple of weeks, then replaced it with a cheap motor oil, in order to flush as much of the water, etc out.
Replace the fuel filters, checked air filter, coolant levels, and managed to start it with the help of some aero-start.
The blade wouldn't lift, so found and repaired a hole worn through the hydraulic lines. The blade now lifts, so could can forward and reverse movement. Couldn't turn in either direction.
Tried to free the steering clutches by dropping the clutch with the brakes on. After a while managed to get one free, but the other was well stuck. I'd taken the drain plugs out of the steering clutch housings, and nothing came out, but on closer inspection, the holes were full of grease, so I poked a screwdriver up and out came at least a couple of litres of water out of each side.
At this point, I had some shelter sorted out at home, so called up the towing company and they brought it back for me. This was about September last year, and I left the cover off the top of the steering clutch housing over Adelaide's dry summer. This must have helped dry them out as now I have steering in both directions. Not sure of the condition of things in there, but the clutches and brakes seem to be doing what they should.
Now that I can steer, I gave it a run around the driveway and dropped the oil in the trans/diff and final drives again, and replaced with more cheap motor oil. What came out was still a creamy brown colour, but after running it again, it appears to be ok now. Once I'm sure I don't need to change the oils again, I'll get the proper grades for the trans/diff, final drives and engine.
I don't want to get into the steering clutches unless I really need to, as I don't have the tools to split the tracks, unless someone can shed some light on the best way to do this. Do you need a press?
I've removed the main clutch because it was staying engaged for a short time after dis-engaging it. As you can see from the photo, the clutch and housing is covered in oil. I've removed the clutch.
Does this look like it would clean up or would I need to replaced it?
Is there any way to tell where the oil is coming from? It looks more like motor oil than gearbox oil, but i'm not sure.
If it's the seal at the back of the crankshaft, can this be replaced without removing the engine?
I do have a service manual, but some things aren't clear from this.
That's probably enough questions for now. I hope I haven't prattled on for too long. Thanks for a great forum, and I'd really appreciate any advice that anyone has to offer.
Cheers,
Hillsy.
