Extra wide tracks
crazycajun
louisiana
Guys any ideas where I can get aftermarket extra wide pads for a D3-4-5 size machine? I recall seeing some 48" pads somewhere? I can change all the pads or just add them on to what I already have.
hvy 1ton
Lawrence, KS
48" pads would require the the track frames to be moved way out or the extra 24" hanging off the outside of the rails. I know of a small dozer with ~32" pads that are mounted off center. The pads are prone to breakage when encountering anything besides soft mud.
Willie B
Mount Tabor VT
Electrician
Offset pads were an option for my Dresser TD7G. The expert I talk to at the dealer has a memory like nobody I've ever met. He tells of problems people had with wear in these tractors. It would be my priority to have centered pads. I'm not sure of your application, but unless you will use this in mud at all times, it'll be useless on hard ground.
Willie
As others have posted, to go with offset pads is asking for trouble. The offset results in a twisting force applied to the track chain that will take out rollers & idlers in a heartbeat. It will also cause problems with track shoe bolts breakage and possibly problems with rail wear caused by the links not running square on the running gear.
Usually a tractor running extra-wide has the track frames offset. This is a factory-built system with the frames spaced maybe 12" wider than standard and will run track shoes 12" wider than the widest available for the standard undercarriage setup.
Lots of wide pads also run an extra set of rails on the outside of the pads and sometimes the inside as well. I'd guess they use used rails that still have tight pins. If they did a new undercarriage with 3 new rails on each side would be beyond astronomical in cost.
lantraxco
Elsewhen
The ones I've seen were half a rail... they started out sawing them in half, nowadays I think you can order the half parts from CAT at least on selected models. Track skidders usually in our neck of the woods, and even an excavator/log loader/harvester or two...
fiat41b
pawnee il.
i can get you the answer
do you need the pyramid style if so they are out there but its like this d3c super swamp dozer cat dealer in Austriala has 6 pads another dealer has 4 in europe i think they are 38" to 40"
cat d4h series iii super swamper has 36' both dozers have wide but short strait blades with tilt
both have enclosed cabs a/c and low hrs $20,000
Used for spent lime sludge lagoons
crazycajun
louisiana
Well pyramid pads would be great. I have to dress and shape 18 miles of levee that we built with an excavator on a barge. My options are find a dozen that will stand up on levee, or bucket dress it all with an amphibious excavator! And let me tell you how boring that will be, much less the cost. I would like to use automatic gps on the dozer.
lantraxco
Elsewhen
Put a blade on a Morooka dumper, be easier, cheaper, faster, LOL.... YMMV
Call Dave Wallace 985-264-0617
Huntoon
California
Sales Engineer. I design OEM tracked undercarriage
I can get you pyramid pads or offset shoes. Triple or single. Depends on your time frame. PM me if you'd like to talk more.
