Willie B
Some use the balance powder inside the tire. My dealer says it is fraud. Why would the extra weight chose to go where it is needed. Why wouldn't it make imbalance worse?
We sell and use it but until last month i didnt know what it did or didnt do. We put it in big pickup tires some times. A guy at work that needed a alinement bad run his tire tell they were so ruff that it shock bad. It had beads in them i drove it then removed the beads vac them out then drove it agin there was a big diffrents the beads made it shake less. I would love to do some more tests. I wish i could use it in my f600 but it has bias with tubes.Some use the balance powder inside the tire. My dealer says it is fraud. Why would the extra weight chose to go where it is needed. Why wouldn't it make imbalance worse?
It might do OK sometimes. If you ever get moisture in the air it can clump together. Running along fine and hit a pot hole. That stuff gets knocked off that spot and clumps together some where else. Then the vehicle will have serious steering wheel jerking and vibration. That will not stop until the speed is greatly reduced and that stuff will redistribute. Then you can go again.Some use the balance powder inside the tire. My dealer says it is fraud. Why would the extra weight chose to go where it is needed. Why wouldn't it make imbalance worse?
I got desperate waiting for my tire dealer to get me a quote on the Accuride wheels. Since he had a set of 1000/20 bias ply handy (Nutech 500) I had him throw them on. I'm not very confident in their longevity, but I need to haul now. Question: Do dump truck tires usually not get balanced?? I'm tired on the vibration and heaving, but my dealer says they don't balance these large tires. Why not?
Any theories?
You need a different inspection station?
I'd think a alignment would be a good place to start for the scallop.
I find that a truck that has been sitting will get a rust spot where drum is exposed, and then you have to wear that off before it will spin freely. I suspect that's whats going on with your front wheel.
A bare truck with no bed on it, and the spring suspension (?) is going to hop with no load on it. Its like bobtailing. Especially if its been sitting, those tires are going to be flat spotted, and its going to take a run to even them out.
dittoYou need a different inspection station?
If all your brake drums and such check out, then I would check the run out on the drive tire assemblies. If you can jack the back end off the ground, and put the truck in gear and let the tires spin with the engine idling, you should be able to see what is going on if it is the tires. I have checked run out on all sorts of tires with a block of wood or two and bucket if needed. You want to check both lateral run-out (side to side movement) and radial run-out (up and down movement).
To check lateral run-out, I put a block or two of wood beside the tire right beside the sidewall. Set it about a half inch or so. If you don't want to run the engine, you can roll the duals by hand and watch the distance change between the wood and the sidewall. It is important to have a block of wood or something stationary close the tire while it spins to give you perspective of how much it is moving side to side.
Radial run-out, just put a block behind the tire and move it to about 1/2 inch or so of the tread and spin the tires around and check for movement.
Its possible you have a bent wheel or something like that, since you said you had the issue with the old tires.
They make run out gauges if you really want to dial in exactly how much run out you have, but normally I am not that concerned with exact numbers as I am about comparing one side to the other.
Good Luck.
