Hi, I have a Drott 40blc (logger) that was converted to an excavator. The bucket mounting pin broke. No one seems to be able to simply supply a 2.5" OD x 24" long hard pin with a single cross drilled hole in one end for a retention bolt. I'm being asked who made the bucket. Is this logo familiar to someone?
I would like to replace the boom point bushings also if possible. Same problem finding simple hard steel bushings. Case says they should be S89466 or S87929 dependent on what logger head it on it. Unfortunately they do not provide dimensions. They are 80mm OD x 2.5" ID x 60 mm long. They can be longer. There are 3 in the boom at this time.
