oceanobob
Here is the Kubota U17 (version with expando tracks) with the demo hammer. The machine runs this breaker pretty well. Bigger hammers (TLB backhoe size) tend to punch holes whereas this breaker tends to crack off a chunk.
On this task to remove the approx 10yd driveway concrete: The approach and the driveway were mono placed and the concrete saw cut the line at the back of the sidewalk.
As to the demo method: Breaker, hand loaded into the wheelbarrow, and then carted into the rolloff container. There was no reinforcing. About 4 inches thick cept near the approach full 6 plus.
The breaker vs sawcut and thumb 'debate'
Haven't got around to the thumb and - Not sure if a thumb would have helped unless I spent the time and saw blade(s) first cutting the slab into pieces.
Yes, the hammer inadvertently makes small pieces although easily cleaned up with a rake, shovel, and wheelcart. Point being: from what I can ascertain, to use a thumb to save/offset labor, there should be minimal small pieces.
This job onsite took less than the Saturday work day what with the mandatory start noise OK at 8 am. Crew was a couple helpers and the house owner, two wheelbarrows.
In this situation with all those cracks / settlement - the saw would have probably bound the blade.
