ih100, the answer on High Drive units is realy no, although the front idler on a D6H etc does have a spacer shim plate under the mounting that can be removed it never is, the likes of D8-9 tractors loose a good bit of steam on the turn with good boots under them, they even had clipped ends on some plates to help with the turn, when you see a D8 run with the idlers in the high set position, or better still drive the mount to get the feeling of how easy they run, turn, spin and seem to pull better, it seems to make it worth the effort, we used to spin the idlers in the night ready for the 6am start of shift, thinking about it my life must have been crap in places, but we thought it was doing the job right at the time, no one in the U.K. running D8H or K's mucks about with this idler task now, probably because they cannot be bothered but 1 thing is sure CAT would not have gone to the trouble if the end result was not worth it, the tractor also seems to run easier - faster.
dog em into 3rd and let em fly tctractors
