Does D11N Ripper fits on D11T?
2machine
USA
OWNER
Does anyone know if D11N Ripper will fit on D11T Bulldozer? Thanks.
2machine
USA
OWNER
D11T SN jel00329
D11N Where the ripper is taken off is 74Z00603
Can't find the ripper group number of the D11N
Not to worry.
There is no easy way to tell unfortunately. The only sure way is to measure up the brackets on the rear end of the 11T Case & Frame Gp, the front end of the ripper frame that mates to it, and the front end of the riller lift/tilt cylinders. See RH illustration below.
The illustration on the left is a drawing of the 11N ripper mounting to the tractor chassis. Here are the details of the Pin As part numbers for upper, centre, & lower for both the 74Z and the JEL machine.
Lower Pin As - 4T-2805. Same for both.
Centre Pin As - 9J-2290. Same for both.
Upper Pin As - 9J-9055 (74Z), 132-0055 (JEL). One P/N does not service to the other. I can't find out what the difference is - no access to the measurements.
Now just because two of the three Pin As Part Numbers are the same does not mean that the ripper frame will be the same width between the "ears". Time to break out the tape measure I think.
2machine
USA
OWNER
We found another D11R machine, 7PZ00825, Will the ripper fit on D11T? Thanks.
Pin Part Numbers for 7PZ ripper installation: -
Lower - 4T-2805
Centre - 9J-2290
Upper - 132-0055
I refer you to my answer regarding the ripper from the 74Z-prefix machine. In this case all three pins are the same Part Number between 7PZ and JEL. This does not mean the 7PZ ripper will definitely fit. The tape meaure has to come out to measure the width of the ripper carriage, etc. This is something that the Parts Manual does not tell you.
nicky 68a
england
You need to be extremely specific on what serial numbers the doner ripper comes off,and what it’s going onto.
Some will fit with some faffing about,and some will never fit properly and you’ll simply waste your money and time.
Be careful here and make no assumptions.
nicky 68a
england
You need to ask your dealer for the 13th edition of Handbook of Ripping.
My 12th edition only covers D11R to D11N ripper compatiblity.
nicky 68a
england
A there a 13th edition Nicky.? I thought it had disappeared into a black hole along with the latest edition of the Performance Handbook.?
You’ve got me there Nige,I’ve no idea,I just assumed there’d be another edition to cover T series
big ben
Vancouver Island
From what I can tell the 50th was published in 2022. Maybe they just had a small Covid break for 2020 and 2021 ?
