Kobe130
After draining down my SK130's fuel tank to replace fuel lines I discovered a ton of rusty scale on the bottom and sides of it's innards. Guess the OEM does not treat the inside of the tank at the factory. I want to put a better locking cap and filler neck on it anyway so my thought now is to remove the tank, invert it, fill it 95% with water and cut out a foot square hole in the bottom to allow sandblasting the scale out (there really is quite a bit). Then I'll weld the hole up and use some sealer to coat the insides of the tank. So that I don't try to reinvent the wheel has anybody had a similar experience and can anybody recommend a good liquid tank sealer/coater which is impervious to diesel? I see there are a few advertised out there. :Banghead:Banghead
Thanks in advance.
Thanks in advance.
