rickrpi
Hello everyone, I have a 2002 Genie TMZ-50/30, serial #T5002-6. It is a Hatz diesel powered trailer mounted lift. The problem I have is that the control panel will not recognize that the engine is running. The "Battery" led light stays on. All controls work, but the auxiliary electric powered hydraulic pump kicks in. I assume it "thinks" the engine is not running and switches over to electric emergency pump. I have replaced the CPU with it's board, connector board, voltage regulator/rectifier, engine wire harness, Hatz engine ignition board, engine ignition wiring, replaced both base and platform control button touchpads. I believe the flywheel generator is working properly, since it produces alternating voltage when running and increases as RPMs increase. 1000CCA Battery is brand new and charging normally. I have been using wiring schematic ES0217C from the Genie Service Manual (part # 65162). I am stumped. I'd appreciate any help....https://www.heavyequipmentforums.com/images/smilies/banghead.gif
