alskdjfhg
Wrapping up the worlds slowest brake job on the F800 digger derrick truck. Once again showing my ignorance here, but got some questions about the clutch.
A few months ago, I was unloading a 3" horizontal boring mill from a rollback truck, weighed 20,000lbs. When you move a machine tool with a rollback, you need either an anchor point or something to pull, to help the load go from the truck bed to the ground.
Since the truck is easy to start and at the time had a working A/C, I figured it would be enough to help the machine make the aforementioned transition, considering the rollback bed was oiled and inclined. Attached picture shows what I was doing.
Chained the 800 to the load, it wouldn't pull the boring mill at all, all I got was that grey "worn-out clutch" smoke so I just figured that I needed a clutch.
Now doing a final test of the brakes with air, with the whole rear end still off the ground, I noticed the wheels would start turning with the truck in neutral. You can stop the rotation by hand, this seems kinda weird to me, is this normal? If not any ideas what could be going on?
As usual, thanks for my answer basic/dumb questions.
