Can any of you old timers out there help me with my '96 Deere 892 ELC? I have had this thing for about 8 years now and it has been a good machine most of the time until this problem came up. The problem started out very simple. I would be using it right along maybe loading trucks and a driver would get out to talk to me and I would have to shut it off to hear him. When I would start it up again I would push the p button to rev it up and nothing would change. I started out just shutting the engine off 1 time then as time went on I would have to try shutting the engine off several times and it would work great. It got to the point that I didn't want to shut the engine off after it got warmed up because I might not get it to throttle up at all until it cooled down again. This all took place over a 3 year period or so maybe 200 hours a year.
I have finally started dumping money into it and now the problem has changed somewhat but is not consistent and does not work like it should. I have changed the stepping motor, angle sensor, engine speed sensor, both hydraulic pump pressure sensors, and even the engine pump controller. I recallibrate it every time after changing something and now as I said it is not consistent but it generally goes through all the rpm settings right except it doesn't rev up as much as it should with each mode. The top setting is about half of what it should be. Is this a problem anybody else has had with these machines or is it like most of my problems being very unique? Any help would be greatly appreciated. I am new to this site and don't know much about it but was impressed with some of the answers that some of you were giving.
