mg2361
Which specific pressure?
Next time; you can check machine status as a "DEERE DEALER MECHANIC".I had the Deere dealer have a mechanic stop by when he was in the area. The mechanic stopped in today and looked the machine over. This machine has factory aux, so there are relief valves on both sides of the valve. It is the second spool from the front, just follow the lines from the boom to see where they go. The left side of the boom is on top. The bottom of the valve stack is accessed through a cover on the bottom of the house.
I don't know which buttons the mechanic used, but the display will read system pressure while operating. This allows setting the relief pressures without breaking a line for a gauge.
The only problem the mechanic found is the rear pump hammers a little bit when he boomed up against the cylinder stops in the h/p mode at full throttle. He thought it will need new barrels and swash plates sometime in the future.
The machine does need pin bushings in the end of the stick. Does anyone have aftermarket suggestions, or should I stick with Deere bushings?
