The grease points Nicky mentioned are for the equalizer bar, not the pivot shaft.
Is there any oil in the pivot shaft tank.? See the attachment for location and how to check the oil level.
IMO they didn't. They offered a machine for sale, it was up to the buyer to inspect it and find all this stuff before parting with the cash.
Very true it was my responsibility to look it over which is why I'm not freaking out, but they did say it doesn't have everything it did. They said the repacked the front cylinders, changed all the oils, it has no super worn parts except the chain, had new idlers, rollers, sprocket.. so the rollers and sprockets looked good but for a blast to the past.. remember it turned out the gears in the left final drive were shattered, there was a napkin stuffed inside the warning light so I couldn't see it blinking, the sensor wires for all filters were cut and bypassed, none of the oils were changed, the front cylinders were not packed, they said it had a new scavenger pump but I had to replace that and found a 1.5" rock inside the pump. I even hired a heavy equipment mechanic to look it over before buying.
Now I know what to actually look at for the future.
