Super mark, Thanks. I will pin the engine in the morning and check the pump tooth. Here is the whole story. Two days ago the number 2 injector line had a leak blowing fuel everywhere. Line was changed and it never started again without a little shot of either. Always started right away before line was changed. The big red light was flashing in the middle of console, but he said been flashing every since he had it. Today O decided what the heck and changed the crank sensor below the ecu right above the starter. Machine started right up. Well I let it run about a minute and pushed the throttle pedal down and hit the high idle toggle switch, as soon as I hit the switch it died again. Would not start unless a little either is applied. After changing the crank sensor the large red light in center of dash is no longer flashing. Tried a few times with the high idle switch. I tried the fast idle switch several times. Sometimes it kills the engine, sometimes it raises the rpms and sometimes it does nothing. Fuel pressure rail sensor has 4.9 reference volts (unplugged with key on), one wire has 10.7 volts,third one has nothing. Ok thanks Mark and Nige, I will check timing in the morning.
