Since it was a nice warm day I spent the afternoon working on the track adjuster cylinder on my D6c today. Got the new cylinder put in, bolted up the idler rod, and got the track back together and the tension adjusted up.
I've been working outside in the drive so I could use the loader to handle the track. Started the D6 and while it was warming up I cleared a spot in the pole barn to park it.
Ran it in the barn, shut it down, and walked around the back and spotted oil all over the right rear final drive......crap.
Got a flashlight and started looking for the leak and found the final leaking badly from the inside sprocket seal. It was coming out fast enough to run 3 or 4 drizzel streams of oil so it must be a complete seal failure.
The finals haven't leaked at all since being worked on about 3 years ago and no oil was present while I was working on the track adjuster. (Leak is on same side I was working on). Can't think what would make it fail so badly just moving it about 75 ft.
Shouldn't have been ice in there since it was plenty warm. Suppose it's possibe I picked up some wire from clearing a fence row, but afterwards I roaded the Cat home about 3 miles.....would have thought a leak would have shown up before now, especially with how fast it's leaking.
Any guesses what might be the cause?
The sprocket will have to come off, but will I have to pull the housing off the final too?
