SwedeDaniel
Hello
have a problem with my d5m or rather 2 problems with the hydraulics,
First of all, the angle is the biggest concern
It can not keep the angle of the blade so I have to sit and compensate for the lever all the time.
I have tested changing overflow valves on the valve block without any results.
Could it be the pilot valves in the hydraulic cylinders that got stuck?
Problem 2
The blade also fails up and down, the same there I have to compensate it all the time, but not as much as the angle
I would have been very grateful if someone had a good answer to my question
Kind regards /Daniel
Problem 2
