Hydraumind
If possible I need a repair manual of NH220 used on the old komatsu Dozer, if someone want to share please PM me
Exactly what I need. Thanks for the reply.
Like I said if you need any more out of the book just let me know, either here or by "Start a Conversation".[/QUOT
In need of the injector and valve adjustment info please
Good to hear!Thanks for that. All set, shes a runner!
anyone know the main timing adjustment of NH220
True and the V-12 1710 is even more fun as you have two different cams to time and like the "K" engines they are adjusted by using off-set keys in the cam gears. Don't make the mistake about installing the key backwards!Main timing adjustment >injection timing< PROCEDURE is the same for NH220, NTC 335, NTA 420, KTA 600. Different injection timing specification for various engine models.
