Engines&aftertreathment
hello,
I,m working with cummins engines and aftertreatment systems. Doc & dpf
With insite we monitor the afterctreathment systems.
Currently we are working on a engine that has frequent regeneration.the engine has low doc inlet temperature 280 degrees.the turbo speed is high approx.10000rpm higher compared with same models and the air intake flow is 125kg/hr higher than normal. This data is measured during regeneration. We found also that there is a little after burning in the dpf.
Does anybody have sugestions and/or ideas what could causes this trouble?
Thanks
Thanks
