Walker1
I bought a very lightly used D-130 backhoe last year. I finally found the time to fab the brackets to mount it to my Case 1845B. The backhoe has been sitting outside with the inlet and outlet hose capped, so it is not full of dirt/water, but I don't know what type/condition the oil is in. The hoe was very lightly used. It has the original paint on it and there is still some on the bucket, original grip tape still on the steps, little wear on the outriggers. I think it was mounted to a small tractor because of the brackets (homeade) that were on it.
When I get it mounted to my skidsteer how should I treat the unknown oil issue? Just cycle several times, then change the fluid in my skidsteer? I do have a portable 110vac power unit that I could cobble together with it, but don't know if that is worthwhile or effective, or needed. I could let the return oil run into a bucket until it runs the same as the oil in my skidsteer.
Anybody have any better ideas?
Also, I still need to install the backhoe diversion valve. I have the Tee in the return line for the backhoe, but there was never a valve installed for it. I can find the valve, but have not ordered it or installed it. In the mean time, can I use the valve for the AUX hydraulics that are on the boom? I will likely eventually connect my Auger, so don't want to make it permanent, but the diversion valve for the Aux circuit is the same part as the additional backhoe valve. FOr that matter I could even simply run hoses to the back of the machine and plug into the rear Aux power. Is there any reason why this would not be a good idea?
