partsandservice
I build the engine in an AXY back in March. 3126b. Get the call that the oil pressure warning came on and engine lost power. Got it to shop. Plumbed in a manual guage . At idle cold have 40 psi and increasing with throttle. After the engine is warm , I hold the throttle down , watching good oil pressure on manual guagg and the oil pressure warning light comes on, I let off the throttle and shortly there after the light goes off . I hook the scan up and watch the live data , the oil pressure that the ecu is reading starts dropping at throttle to about 14 psi and this is when the light comes on. I unplug the oil pressure sensor and a code pops up for fuel actuation pressure low. Then I unplug the fuel actuation sensor data says no input from oil pressure sending. So they have the same plug and are close enough to each that they were hooked backwards. Swapped them and all is good. I would assume that the swap was done at the time of rebuild. So the question now is what psi should the fuel pressure delivery should be at throttle. It was obviously higher untill this point or this issue would already happened. It does not trigger a code for low fuel delivery at this point.
