Red637E
Looking for some insight into this problem. This tractor was loosing hydraulic oil with no visible leaks. When we checked the transmission level we found it to be way high. We tend to loose around 2-5 gallons of hydraulic oil into the transmission daily. The only two places that hydraulic oil gets near the transmission is the steering motor and the brakes. I pulled off the steering motor and had it pressure tested and it has no leak down. I'm thinking the only other possibility is a leak on the brake curcuit. Has anyone ever incountered this? Any help would be appreciated.
