Here we go. It's a service mag, not letter. SEPD0888.
Nige, can you make the pictures appear. I don't know how to.
Product: MULTI TERRAIN LOADER
Model: 287B MULTI TERRAIN LOADER ZSA
Configuration: 267B 277B 287B Multi Terrain Loader ZSA00001-UP (MACHINE) POWERED BY 3044C Engine
Service Magazine
2007/05/14 Media Number -SEPD0888-00 Publication Date -14/05/2007 Date Updated -14/05/2007
i02753237
Installation of New Crankcase Breather {1317**
SMCS - 1317
Multi Terrain Loader:
267B (S/N: CYC1-1482)
277B (S/N: MDH1-5379)
287B (S/N: ZSA1-4639)
Skid Steer Loader:
236B (S/N: HEN1-6749)
246B (S/N: PAT1-5522)
248B (S/N: SCL1-2044)
252B (S/N: SCP1-4599)
262B (S/N: PDT1-4910)
268B (S/N: LBA1-2089)
Service Magazine SEPD0861-00, 30 October 2006, "Installation of New Crankcase Breather". Disregard this article. See the replacement article that follows.
Description of Change: To prevent freezing, a new open breather has been introduced.
Adaptable To: The new open breather replaces the existing breather.
NOTICE
Ensure that the hoses are routed correctly. If the hoses are routed incorrectly the hoses may wear or be damaged. Also ensure that all plugs are secure. Dirt and other debris can enter the engine causing engine failure.
Illustration 1 g01238926
1.Disconnect the old breather hose (2) on the engine side from the fitting (1). Insert a 9B-7237 Bolt (4) into the end of the breather hose. Use the 5P-4961 Hose Clamp (3) to seal the breather hose.
Illustration 2 g01238930
2.Attach a 5P-1442 Hose (2) to the fitting (4). Route the breather hose (2) toward the bottom of the engine. Use the 5P-4961 Hose Clamp (3) to seal the breather hose. Use zip ties to attach the new breather hose (2) and the old breather hose (1) together near the fitting (4). Also use zip ties to attach the new breather hose (2) to the fuel lines (5) toward the bottom of the engine near the flywheel housing.
Illustration 3 g01238934
3.Disconnect the hose (3) from the pipe nipple. Insert a 7W-0917 Plug (1) into the end of the hose. Use the provided 9M-7958 Hose Clamp (2) to seal the air line.
Illustration 4 g01238935
4.Attach 262-8088 Hose (4) to the pipe nipple (2). Use 9M-7958 Hose Clamp (3) to seal the hose. Insert a 7W-0917 Plug (5) into the other end of 262-8088 Hose (4). Also use a 9M-7958 Hose Clamp (3) to seal 262-8088 Hose (4). Use zip ties to tie the old hose (1) and the 262-8088 Hose (4) together.
Copyright 1993 - 2013 Caterpillar Inc.
All Rights Reserved.
Private Network For SIS Licensees.
Sun Dec 22 11:47:48 UTC+1000 2013
