D6C or D6D not sure how your planing on using it so more info would help.Heres a few difference that you might want over the other.Sure others on here can and will add.
D6C's are plentyful and parts are easy to get.If you go with the D6D the hydraulic controls are better the tilt and lift for the dozer blade are on just one level a wobble stick.Where the tilt on the C is a foot control and you are spread out using it at times.
The C is better balanced,which helps when dozing.Cable units are added at time for extra weight and helps balance the machine out even more.
The D if you get it, make sure you try and find one with the long undercarriage 7 bottom roller frame machine.Better balanced the 6 roller framed amchine on a D really isn't balanced worth a darn.I have owned both.
Unless you need the extra flotation i would stay away from a lgp machine,the blade it wiser ,but not as tall as standard blade.Not real good for digging out stumps and clearing trees.
I prefer semi-u blade like on the newer 6,the older straight blade always seem to not want to carry dirt as good plus didn't and doesn't roll the dirt like the semi blade does.
Those when in wet gummy clay the older 6 blade tend to just ride on top of the grade when it get full and if you try to force it into the ground more it just forces the front of the machine up and you loose traction more and trend to ride harder because the machine is riding up on the rear sprockets.
But with that said i have spent a lots of hour on a 6 sized Cat machine.They have been pretty dependable for me over the years,but like everything depends on the previous owner the shape of the machine.Good luck.
