I have a cat d6c dozer , the decelerator pedal will adjust throttle back to idle speed when depressed and not return to set governer speed.I have to move throttle manually back up to higher rpm each time I step on decelerator pedal.If I move throttle off idle speed and mov decelerator pedal toward seat engine speed will increase. Not sure how linkage is suppose to work, any advice would be appreciated, thank you
