brian falcone
have a 1996 d250e end dump. replaced filters ...drained tank. on flat ground the truck will move fine. even heavily loaded. as soon as it hits any type of incline it will sputter and cut out like its running out of fuel.it doesnt stall but it gets very rough. it doesnt matter if its loaded or empty. any change in grade will cause the problem. even streeting the truck empty on the road... it gets even worse when the fuel level is below 3/4 of a tank l. doesnt matter what gear its in .mechanic said it could have a hole in the pickup tube in the tank ? hope this isnt the problem as theres no way to replace the tube. theres nothing in the filters...water separator is clean and no water or debris was found when the tank was drained. any ideas ?
