I need to do the bucket cylinders on my 931B. I'm going to cut an octagon wrench out of steel to get the gland nut off and was hoping I can just take the rods in to get the new seals installed. The cylinders rods look like new but started weeping out the end too much . I don't think I need the barrel honed and I can polish the cylinder rods if they need it. Is it common to have a hyd. shop just change the seals on a machine that doesn't get a lot of use? One place suggested it could cost $400-$900 per cylinder to rebuild if I took the complete cylinders in. That seems like a lot money for cylinders that started weeping after 30 years. I think the cylinders use a bolt to hold the piston rather than a nut and I don't know if they have Loctite on them but are really tight. That's why I was thinking of having a hyd. shop do it with the proper tools. Was also wondering if I take the cylinders apart if the cylinder barrels will rust being open in cold weather for about a week. I have the machine in a non heated shop. Would it be better to wait till spring? Just looking for opinions. I've done seals in my skid steer with no problems but these are little heavier duty cylinders.
