- Joined
- Jan 21, 2007
- Messages
- 13,395
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
Cat CS533E ASL 150-200 serial number range. 2600 hours
A couple of issues -
The high side vibrate won't engage. The switch on the operator station seemed to be sticking on the high side so replaced it, didn't fix it. Low vibrate works. There are a handful of relays in the fuse box. Checked vibrate fuse (only one) and it was good. Is there a relay for the high and low vibrate? The diagram doesn't label the relays.
Second and more serious issue. We have been using the machine steady for the last three days. This morning during the walk around we noticed there was what seemed like oily dirt on the one factory hole on the inside of the drum.
This was what it looked like this afternoon, it became much worse.
I need some help as I know very little about the vibratory system and what could be causing this. My limited mechanical mind tells me the high side vibrate issue is electrical and the leak in the drum is not related to the problem.:beatsme
I went to the online Cat parts diagram system and when I clicked on the drum/vibrate system it said "no documents match your search".
There is also a small fuel leak at the pump and a hyd. leak at the for end of the hyd. pump but not bad enough to break it down yet. Poor b*****d of a machine shakes itself to death.
Any help is appreciated as it has to complete this job, with or without vibration. We can use it as just a static compactor with no vibration until I can get it back to the shop for more "invasive" repairs.
