cb75
Good evening, Working on a Cat 980H s/n JMS02203 It will not go into gear, forward or reverse. Checked with ET and all the electronics appear to be working as far as operator inputs, park brake switch, etc. the thing that is odd to me is, when you select forward or reverse you get a status flag that says "latched to neutral' The park brake is released, all switches are in a correct position, but I keep getting this message.
The only other time I've see that message was on 836K compacter, it gives that when you put it in gear without moving the steering joystick lock. This machine has the steering wheel mounted transmission controls so it doesn't have that lock.
I was thinking it could possibly have something to do with the neutralizer pedal, but there is a switch that turns that function off and it won't shift into gear weather its off or on.
I will be back working on it sometime tomorrow. If anyone has any ideas or knows why its saying "latched to neutral" please let me know, I'd greatly appreciate it.
Many Thanks, CB
Many Thanks, CB
