Hello friends,
I have a problem with a wheel loader 962G (sn 3bs00338), the lifting or the tilting function not working suddenly. i checked with diagnostic software ET and i realised that the error 0358 FMI 05 wasn't active error but was appeared occasionally about 100 times. I have done those test:
- tested cables and plug, resulted OK.
- changed the implement pilot pressure solenoid with new one.
- measured resistance of the contacts J2-3 and J1-8, result = 20ohms.
Would you mind giving me any solution for this problem?
Thank you in advance.
Artin
Artin
