tctractors
To test for fuel (Diesel) in the E/O put an amount on a bit of Shop Towel paper and set alight the paper if it flairs up its diesel doped, the fuel transfer pump and the injector pump have waste pipes on them that should drip if the seals are failed, these pipes often get pegged up with dirt so check them out, the hour meter face is another fuel drama spot that people seal off fuel leaks only to knacker their engine, the longer you leave the fuel tank tap open the more fuel will drop into your sump?? I would turn the tap off under the tank to save some mess and cost.
tctractors
tctractors
