JakeHarrington
i have a cat 955h see:60A track loader that i just got running after it sat for probably 20 years.
the machine started and ran great but at first the tracks had no movement but you could here the engine bog down when you moved the shifter. the converter oil gauge said it had great pressure. after like 10 minutes of shifting forward and reverse everything started working properly.
it has a power shift transmission and the oil on the dip stick looks really thick. i want to change that oil. does any one know what type of oil this takes and how much of it?
also is there converter oil and then also tranny oil?
drains and fill locations for all this?
any other recommendations for thing that i should look at before running this old ?
Thank you in advance
Jake
Jake
