JustinG
No actual plug, should be a hex head on the side to open the valve. I will try to get a picture of my sump I have off my engine.
OK, my bad. I thought you wanted to re-shell where possible. Berco is one of the major aftermarket undercarriage manufacturers in the world. However if you go down the road of re-shelling on the rollers on the opposite side that are in better condition be sure you advise whoever you buy your parts from of any markings you can see on the rollers because the chances are that Cat OEM spare parts will most likely not fit aftermarket-brand rollers.Nige,
Those are the rollers I planned to replace from the start. The others on the other side don't look all that bad, I brushed off some of the dirt and was able to read some info on them, Looks like BERCO CR1317 C Made in Italy. .
I think you should be able to get chains to fit your existing shoes , it's just a question of being aware of the compatibility issue regarding bolt hole pattern and taking appropriate steps to ensure it doesn't catch you out - i.e. cost you major money. I think it's a good idea to send him a diagram of the track shoe bolt hole pattern plus also give him details of the shoe bolt diameter.On the shoes/chains. I'm going to talk to Jeff @ offroad and give him the run down on the situation, i.e. aftermarket chains, and see what he says. I totally agree, a few hundred dollars vs $1500'ish is a no-brainer. If necessary I'll send Jeff an outline of the shoes/w bolt pattern.
On my loader the hole in question is used for a place to bolt rock guards on.
Yair . . .
dmcschultz
On some tractors and applications rock guards can help keep the chains aligned and stop the machine walking out of tracks thus allowing maximum hours on components . . . I guess you didn't need them. (Big grin)
Cheers.
Another vote for SALT, whatever the brand.
Also I wouldn't say that mixing brands between rollers & chains will do much. Let's face it you're won't be the first person to have done it......
