precision dirt
- Joined
- Apr 17, 2014
- Messages
- 86
- Location
- brenham tx
- Occupation
- machinist, fabricator and owner of precision dirt
I know most scrapers don't have much for brakes but i road mine alot so I need decent brakes. My cab side tractor brake stays engaged at startup and only way to get it to release is pull plug out of air chamber but then i don't have service brakes on that side. Right now i have to install plug, start machine and air up, release brakes ( at this time cab side brake stays engaged) until I remove plug. I can run this way but would rather not road machine. All over service brakes hold but are limited on pressure because of whats escaping system on this chamber. I have replaced diaphragm and cleaned double check valve on chamber.
Could i have a problem on the relay valve? Possible stuck assembly on one port? I have never been into one of these air relays on this machine and wanted a few opinions for the ones that have some experience.
