Gents,
I am trying to remove my steering cylinder. leaking.
How much force is acceptable to apply to the cylinder to remove it?
Spanner nut off, snap ring removed. Tap on the spanner nut end? with what?
Any good tricks her to get the cylinder out?
I think I can pull the piston out from the left end (snap ring side) if I push the end back inside to remove the internal snap ring per Cat diagram.
Your thoughts are appreciated. I will try to attach photos.
