Ideally how many horses do you want....?
Kinda what I was thinking when I previously posted about having multiple choice answers to your question.
........ What are you planning or wanting to do ?? that you are not satisfied with 385hp.
........ the 3406 is one mother of a tough engine, capable of tons of hp and will live with a real operator on the right hand pedal ..... as I said mine is the 3406B 425hp ...... its been fueled up HOT
.... putting 487hp dynoed to the ground ...... but when I had hired drivers running it they took out turbos not knowing how to shift, fueled-up the turbo spins at a higher rpm creating higher boost .....the drivers would stab into the throttle, or not feather out of the throttle either when grabbing a gear, causing the turbo to make a chopping sound which is a sound of the turbo trying to stall, which in turn twists the centre cartridge shaft in half .... another draw back these days is a guy driving with those bad habits will cause the puppy to smoke black under a lugging pull like you never seen before,:cool2 the smoke would come outta the stacks so heavy that it would fall to the ground at the drivers (rear drive axles) ......cars following you would turn on their wipers and it would only smear ....lol... but when shifted properly will run pretty clean. In the old days that was considered COOL :notworthy...... with all of the epa cops around today, I don't think you'd want to take a chance by over fueling an engine.
If you NEED more hp giving it 50hp at the fly wheel will not be a problem. ..... that is easily done at the pump by the right guy setting it up.
