Got called out to a piece of equipment and complaint was engine and hydraulics overheating. Story on this machine is they got it stuck in sand and water and engulfed the whole engine bay with water sand mix ( it was a mess). The sand was so bad that it ate the drive belts clean off, it got hot enough to derate it but we got it out finally. Got it back to shop pulled counter weight and side panels to get sand out did not remove cooler but was able to pry back fan shroud to get access to inside of coolers (coolers are not stacked together but side by side). Used water and air to remove sand from fins until water was free flowing through. Machine is not building pressure like a head gasket blown. But under heavy working conditions is when it gets hot. Kind of stumped on what direction to go next. Have access to cat et but I usually use my Cando scanner just faster than the laptop. It has codes for the overheating cooling and exhaust. Just throughing this thread out try and get some advice before I call the stealership. Thanks in advance
