watglen
- Joined
- Apr 3, 2009
- Messages
- 1,324
- Location
- Dunnville, Ontario, Canada
- Occupation
- Farmer, drainage and excavating contractor, Farm d
1000 hrs on unit. 2005 Cat 257B mtl.
About 2 months ago the unit blow the suction line off the main pump. At least I think its the suction line. Its the only soft sided hose going to the main pump. It originates at some sort of valve bolted to the belly pan.
Today, it blew the same line. There is enough pressure in that line to spray oil. Its the pressure that has me scratching my head. Is there a system that creates pressure on the suction side of the pump? I am thinking it is supposed to have a little pressure, but something is causing it to be to much for that hose.
I worry replacing the hose won't do it.
Ken
Ken
