Case Yellow Paint
Discussion in 'General Industry Questions' started by Boss, Mar 17, 2011.
  1. Boss
    Boss Well-Known Member
    Jan 7, 2011
    102
    Minnesota
    We are looking to re paint our 1840s and 1845s skidsteers, and can't seem to find the Case Yellow code, or where to buy it? Also where to get new stickers would be nice to know as well.
  2. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    3,767
    Andrews SC
    According to Case, that's not yellow, it's "Power Tan". I got mine from the Case dealer, but I was only doing one machine.
    Good Luck.
  3. shopteacher 1
    shopteacher 1 Well-Known Member
    Apr 22, 2010
    153
    Delaware
    I would check with Tractor Supply or Napa. I use Napa's industrial coatings enamel on trailers, tractors implements etc. I know they have a premix for Cat, John Deere, Ford and IH along with others. You can use it with or without a hardner, I always use the hardner.
    John
  4. 621_Rocker
    621_Rocker Well-Known Member
    Jun 8, 2009
    70
    Coeur dAlene, Idaho
    I have used NAPA's Cat yellow before and found that it color is quite a bit off. If you are not mixing brands it might be okay.
  5. diggin02
    diggin02 Active Member
    Aug 4, 2009
    35
    central il
    Try Diamond Vogel Paints. Just Google them for the #. I really like their paint and its alot cheaper than Sherwin Williams or Napa. We always buy in 5 gal. buckets.
  6. DiamondLTruckin
    DiamondLTruckin Well-Known Member
    Mar 22, 2010
    107
    Truck Driver / Mexican Dragline Operator / Mechani
    Wyoming
    I've painted a couple demo derby / race cars with Cat Yellow Napa paint. It looked close, but then again I never parked the car next to any Cat machinery. Most paint outfits can match a color to your Case color. Probably what I'll end up doing for Old Cat Yellow for a future project unless anybody here has any other sources.
  7. shopteacher 1
    Apr 22, 2010
    153
    Delaware
    Hey Diggin,
    Which paint of theirs do you use - the industrial coatings or heavy duty coatings?
    John
  8. SKM Excavation
    SKM Excavation Active Member
    Feb 24, 2011
    35
    Heavy duty Mechanic bye trade. Self employed cont
    Sask,Canada
    I am a former case mechanic the colour is case power tan and you can get it at any case dealer Ag/Const it comes in a spray bomb or in a gallon/quart for use in a spray gun. The decals will be available thru parts dept they should be able to order them or at least point you in the right direction they may be pricy though.
  9. Zeke
    Zeke Member
    Mar 28, 2011
    17
    Aggmin Equipment sales rep for SW Ontario.Link Bel
    London, Ontario
    You can probably get the decals made by a good local decal guy.He'll just need to see the old ones.Should be able to save a bunch of cash that way.
  10. Willis Bushogin
    Willis Bushogin Senior Member
    Nov 7, 2007
    855
    owner
    NC
    Coming from someone that repainted his 1840, here is a few recommendations
    AS usual, clean clean clean clean, sand sand sand sand, cover all exposed cylinder rams, if the paint gets on the ram it might wipe your seal out. A skidsteer is one of the hardest machines to clean and paint. I got a decalsign shope guy to come and take pictures of the decals. I dont remember what he charged, but it was about half what Case wanted
    I painted it with Napa industrial coating Cat yellow. The paint held up pretty good for a while, then it started to fade. I went to Cat yellow, because I thought that original paint was UGLY.
    After this, I never used the industrial coating to paint a machine, even though I still use it on dump truck bodies and truck frames. I use single stage paint, for all machines, it just holds up better, cost a little more, but its worth it.
    I use Napa and Nasson brand, they are on the lower end price and still real good. If you want to keep it the same color most Napa stores has a paint gun that can get real close to the original color. I never was impressed with Case paint either, nor Cat paint
    Dont forget clean and sand and its a job to do it on these machines
    Good Luck
  11. Boss
    Jan 7, 2011
    102
    Minnesota
    Thanks for all of the suggestions, we have contacted a nearby Case dealer and will be checking Napa this week. I'll try to get some before and after pictures of the fleet to post on here.
  12. WV earth mover
    WV earth mover Well-Known Member
    Mar 7, 2011
    110
    WV
    We painted our 580L and then used the case color on a tag trailer about 3 years ago no rust yet paint was 40$ a gallon at dealer also did a 1845C about 6 years ago then traded but it came out great
  13. Lightning Bolt
    Lightning Bolt Member
    Apr 30, 2012
    22
    Bay Area
    What color are you guys painting the ROPS cage?
  14. Steve Works
    Steve Works New Member
    Apr 24, 2013
    4
    Cluj, Romania
