JNB
Just thought I'd post a few preventable issues that I've heard about or discovered for myself in the last few weeks.
Remote Oil Drain - Remove the rear small belly pan inspection plate. Dirt gets trapped down there around the remote drain connection to the oil pan, hardens and vibration can crack the oil pan. The repair requires engine removal. If the (2) bolts holding the cover twist off upon removal, it's easier to flip the cover plate around, drill and tap new holes for the bolts then easy-out the old bolts. My machine had been regularly pressure washed and was full of mud wrapping around the oil pan. Luckily the mud stayed moist enough that the pan hadn't cracked. Thanks to KSSS for the heads up on this one, I checked it out before it became a problem.
Main Hydraulic Pump Charge Lines - One or both of these lines can rub against the belly pan and burst. One of mine did while I was working yesterday and shut down the machine. The fault code #4431 indicates a parking brake circuit disruption that points to an electrical solenoid or wiring problem. I wish it was that simple. Actually mine lost all hydraulic charge pressure so the brake and hydraulics wouldn't work. When trying to overide the code, pressing the "operate" button empties the hydraulic tank immediately into the belly pan. The field service tech says that mine is the fourth one he's seen in the last few months. Replacement of the hoses involves removal of both tracks, drive motors and rear undercarriage connection mounting plates for access. Of course, I'm going to try doing it myself cause I like torture. I will be installing the velcro version hose sleeves with tie wraps to every hose I can get to down there.
Hydraulic Hose - I don't know what this hose actually supplies, but I saw this while we had the cab up. The hose at the top of the pump rubs against another coil sleeved hose (a/c?) entering the left side of the cab. I'll add a hose sleeve there too.
A/C Condensate Drains - I noticed this while the cab was up as well. Both rubber nipples were clogged. When the cab was flipped all of the water dumped on the cab floor. The service tech says to give each a short blast of air to clean. There's probably another way to clean them out, but I'll have to look at it a bit more after we recover my machine from it's resting place on the only high spot next to a creek...over a mile from solid ground...and it's raining now.
