Case CX210
Baylward
Mississippi
I'm getting the codes 0364 fuel system com error and a 0365 fuel system low. Has the VP44 injection pump crapped out again?
uffex
Lincoln UK
Admin
Good day Baylward
Please see attached hope it is of help.
KR
Uffex
  • Case response.pdf
Coy Lancaster
Arkansas
service tech
The codes are the same as the Cummins engine error codes, for your information. The 364 code is fuel pump control module, CAN communication error - abnormal update rate. The 365 code is fuel pump control module, supply voltage circuit - shorted. So yes it's the VP44 pump again, have you changed your lift pump and fuel return relief valve lately? Do you have the updated inline fuel filter on this machine? Fuel pressure and supply is everything to these pumps.
Baylward
Mississippi
I changed the lift pump when I put a new injector pump on it last time. Didn't know anything about a return relief valve or updated inline fuel filter. Thanks a bunch. Guess I need to get another injector pump on hand.
Coy Lancaster
Arkansas
service tech
There was a buletten from Case some years ago on the fuel filter update. Check the inline filter that you have and clean out settlement bowl at tank. Sometimes the banjo bolts get stopped up with trash and there's a filter in settlement bowl you can clean.
Coy Lancaster
Arkansas
service tech
Oh and btw the relief valve is at the end of fuel return line where it connects to line going back to tank.
