So I finally got around to taking some pictures of the bent rod:
Bent Rod
Gouge
I dropped by the hydraulic shop in town here. The guy there said if I got the rod straight and the gouge smoothed out that it would okay to use for occasional use. It may leak a little, but since I am only going to use the backhoe for personal use and the stabilizer doesn't see that much use, I think it will be okay too.
Given that the chrome is worn, would you not be better off to replace the rod and be done with it? At least that way you will do a proper, long lasting repair job rather than a half job that will need to be revisited at a premature point.
I considered replacing the rod, but at $300, I am going to take the chance and use the old one. The only thing I will be out is a seal kit if it doesn't work. So it's worth the gamble for me.
I rotated my rod 180 degrees in the cylinder and works good, maybe it will bend back to strait lol if not can replace rod just a lil work and parts,,,,don't own equiptment if afraid of work
I will probably rotate the rod when I put it back together. But I don't think it will bend back straight.
zef_66 if you work for a welding /machine shop best bet is buy new piece of shaft & weld your eye on it & thread the other end did that with mine trevor b
I had considered that as well. And if using the old rod doesn't work, I may go that route. But I worried about the rod rusting/oxidizing since it wouldn't be chromed. I don't have a building to keep my machine in right now, so it sits out in the elements all the time.
I am looking to get the rod straightened this week and back together so I can work on it over the weekend and get the machine back up and running.
