Colonel Clank
- Joined
- May 4, 2017
- Messages
- 23
- Location
- Adirondack
- Occupation
- Semi-retired building maintenance tech
The dipper cylinder started leaking from the gland when I was pushing on a tree. I want to get tools together to take to the machine which is at a remote location and am trying to find the size of the piston cap screw head so I can get the right size 1" drive sockets. The machine is an '87 and the dipper cylinder shaft is 2.5". The service manual does not mention the size of the cap screw.
Same for my stabilizer cylinders. Shaft size on stabilizer is 2".
Btw, after heating the cap screw to about 400 degrees f to soften the loctite, I plan on using a torque multiplier (like the ones that are designed for truck wheels) to remove the cap screw. Service manual says 2800 ft/lbs!
Thanks,
Kevin
Thanks,
Kevin
