Case 580C Clutch Switch Loacation
TheFixer
MI
Can someone post a picture of where the clutch cut out switch is located on a 580C? I have a bit of a project machine, and the switch is missing and I don't see where it should mount. I see it in the electrical diagrams, but can't find a mounting bracket for it.
DirtyHoe
Albany, Oregon
Super slow. I've been busy with work. Plus out here in Oregon we had a nasty frozen rain/ice storm that I have spent the last 3 weekends cleaning up .
Resized_20210213_143404_785.jpeg Resized_20210213_162215_694.jpeg Resized_20210215_093305_7619.jpeg
stinky64
java center ny
big truck wrench/fixer of things
Thanks for the reply, deleted my post, didn't want to screw up Mr. Fixers post, so for the out of place reply from Dirty, Stinky's faulto_O It's a Dirty,Stinky shame:D
TheFixer
MI
Thanks for the info. I have the manual shuttle, so the floor and dash switches are not there. Looking for the starter cut out switch. The one pic might be it, but I can't seem to find that in the parts book. I see the 2 brake switches, but not the clutch.
This photo you posted looks close but can't find it in the manual.
DirtyHoe
Albany, Oregon
Are you after the neutral start switch(#20) mounted in the 2-speed shuttle housing? I think the clutch cut-out switch is only in the power shuttle model, not the manual model.
Steve
TheFixer
MI
Yes, that is probably the one. I can stop looking under the dash now!! Thanks,
outlawspeeder
USA
I think you might be looking for 52. The switch is in series from the starter button to the starter solenoid. Small wire on the starter. The neutral safety switch has two buttons things that clips slide onto. They pop off when the clips get old.
Hope this helps
