Hopped out of my Case the other day and left it running, when I went to hop back in I noticed a massive amount of oil on the ground under it (clear oil). I shut it down and slid under, to find everything under there dripping with oil (under the cab area, soaked the parking brake). I poked around where I could, but didn't find any loose lines or loose connections. The fluid that is leaking is completely clean, and appears to be coming out under high pressure, as it has done a great job of cleaning off the underside of the machine. Everything still operates fine. Recently I have been going through a lot of Hy-trans, so I thought that perhaps my consumption problem just got a lot worse. Poking around there today, I found that what I believe to be the shuttle, is loose. When in neutral I can move it a bit by hand. (can't move it by hand when it's in fwd or rev) Now... Why is it loose, and how do I tighten it? (without taking the whole thing apart). I am building a house, and I am way behind schedule, it's getting cold and my workshop isn't built yet... Other than spending $20/day on Hytrans - is there a quick fix for this, until I can get it in the shop (once built!)
Much appreceated!
Much appreceated!
