I was moving some dirt today in my Case 530ck with the gas motor. I had a load in the front loader going through a narrow gate. There is a 6” hole that the left front tire dropped into. As the tire bumped the other side of the hole it bumped the steering to the right a little, then the steering went full right by itself. If I lift the front wheels off the ground and turn the tires to the left by moving the tire (steering wheel has little effect), then as soon as the engine is running the wheels turn to the right again.
I suspect I have blown a left cylinder seal, so I will try to remove it from the spindle and see it it offers any resistance to pushing in/out.
Any other ideas would be appreciated.
Thanks,
Thanks,
