Case 450 Dozer Problems
Rick Rowlands
Youngstown, Ohio
My dad has a Case 450 dozer. He said that today while running it he heard a snap and the engine quit. When he tries to start it only the flywheel turns. Broken crankshaft most likely. The engine is pretty worn and he had been considering doing a complete rebuild, but now might try to find a new motor for it.
I'm trying to find a bit of info. about this machine, such as what engine it has and about how old the machine is. The serial number is 3062036. We won't know for sure if this engine can be repaired until we drop the oil pan.
JimInOz
Victoria, Australia
The early Case 450 had a Case G-188D Diesel. (I think this was used in some backhoes & 350s too).
450B had a Case G-207D engine.
Hope that helps a little...
stumpjumper83
Port Allegany, pa
Movin dirt
188 & 207 case diesels are twin siters, only difference was the head. They were in alot of older case equipment. 580's, 586's, 1845's, 350 & 450 dozers, w-7 wheel loaders I think... And in 530 & 630 farm tractors. Very common little motor.
TractorDealer
Nashville, TN
Am trying to reach Stumpjumper83 about a message he posted...I need a radiator and shroud for a Clarke Airborne and he mentioned in another post about a party that restores, etc. them. Can I find out who that is or where you talking about Syltech in NY (they didn't have one currently)? thanks!! Since I'm a new member I can't contact you apparently so sorry about posting this here. Robert Moline in Nashville, TN or- cashmoline@hotmail.com
willie59
Knoxville TN
Service Manager
Once you make 3 posts to any thread (except TGIF), after a short period of time you'll become a Junior Member and can send a private message to another member.
catd68u
oklahoma
OOps
your right in your thoughts about the crankshaft, however I had a jd450 once that sheared the crank bolts and dowel pin off the flywheel would spin but not the engine. If I were you I would pull the #4 injector and see it is building any compression in that cylinder. Parts are fairly easy to get. After market offers most things. I used a place call www.brokentractor.com for most of my parts. Hope this helps
case450
kentucky
Case motor
We have case 188 & 207 engines that will fit your dozer here in kentucky. We have alot of case parts some jd parts /also case & john deere winchs. Or we may buy your dozer if it for sale .606-845-3055
special tool
Bethel, Ct.
Crankshaft.....naaaah
I'm going out on a limb and saying that your cam chain snapped.
Takes a heck of a lot to break a diesel crank.;)
I betcha it spins REAL fast on the starter, huh?:tong
CMSMOKE
ligonier, pa
The case 188 and 207 use timing gears, for certain. I can say I've yet to see a deisel engine that uses a timing chain.
kev
AUSTRALIA
retired
I have a case D450 crawler 1975. Tractor will not drive changed all transmission oil and fillter, checked charge pump filter and washed it. Oil apears to have lots of air in transmission. Toque compression gauge reads up to 25 and 50. Transmission gaug is adou 150 checked for possible air leaks can't find any. Help
kev
AUSTRALIA
retired
Have caseD450 crawler 1975. Tractor will not drive changed all transmission oil and filter, checked charge pump filter and washed it. Oil apears to have lots of air in transmission. Toque compression gauge reads up to 25 to 50 . Transmission gauge is about 150 checked for possible air leaks can't find any. HELP
