jacobd
Just had a problem pop up I'm hoping someone can help with. Machine was running fine, digging out a stump, nosed down at a steep angle and heard a very slight miss. I backed out to level ground and played with it some. At this point once you move the throttle above halfway or so the engine begins to miss and stumble and blow lots of white, acrid smoke out of the exhaust. It Idles fine and sometimes you can slowly sneak the throttle up and it will keep running correctly but usually it begins to miss. I suspect I may have run low on fuel as it was low enough to trigger an audible alert at one point, but it quickly went away and I forgot about it and kept working like a dummy. I added what fuel I had on hand (2 gallons or so) with no difference. Also I have no warning lights on in the instrument cluster.
Could I have sucked some air or trash into the lines and maybe it's starving for fuel now? What can cause these symptoms? Thanks for any help.
